Asus zenfone Max pro m1 SD card can't move the file
muthum570
Im facing sd card write access problem can't move any files to sd card couldn't move file error unknown
28 REPLIES 28
muthum570
Christine_ASUS
Hi muthum570
As I mentioned twice before, if the issue persists, kindly reply me as below
1. Which SD card brand are you using? Please provide me the model link of current SD card.
2. Do other SD card brands work in your device on V432 or not?
I'm using SanDisk microsd and also samsung memory card has this Can't move file unknown error issue on my Max Pro m1 the problem isn't memory cards beta 3 and beta 4 have this unknown error issue
Christine_ASUS
Community Legend II
Hi muthum570
Sorry for the belated reply due to our national holiday from 1st Oct to 11th Oct. I just tested my device in V432 with SanDisk microsd card and I didn't encounter the same situation.
1. Have you ever unlocked or rooted your device before?
2. Can the Sdcard in your device still storage the file?
3. Can the Sdcard still be used in the PC properly?
muthum570
I'm smashed those two memory cards and problem solved thanks for your help 🙏
ASUS_Bot
Rising Star II
