Asus zenfone Max pro m1 SD card can't move the file
muthum570
Im facing sd card write access problem can't move any files to sd card couldn't move file error unknown
28 REPLIES 28
muthum570
Sd card worked android 9 and android 10 beta 407 and 424 build im facing this problem is 429 build
Christine_ASUS
Community Legend II
Hi muthum570
Thank you for your reply.
1. Which SD card brand are you using? Please provide me the link of the model.
2. Please provide me the result if other SD card brands can work in your device on V429 or not.
I will check with my device if I have the same SD card. If I do not have the SD card, I may need you to provide me logs for further checking.
bhute_smit24
Christine_ASUS
Hi muthum570
Lmao, you're the coolest mod I've ever seen
AJ1
Rising Star II
I'm also getting same issue on max pro M1 with latest patch updated
I am facing this till last two updates, i have also formatted it through PC. With help of diskpart also but still not resolved. I thought my sd is faulty but i now i get to know that every iser of max pro m1 is facing this..😶
