Asus zenfone max pro m1 Android 10 beta 2 vs beta 3
saitejaakula
Can we upgrade to beta 3 (.429) from beta 2(.424) of Android 10 recently released for asus zenfone max pro m1? Which is better?
9 REPLIES 9
saitejaakula
Yes, just like updating from android 9 to android 10.
bisukaisth097
vishalsr098
https://zentalk.asus.com/en/discussion/31412/asus-zenfone-max-pro-m1-android-10-beta-2-vs-beta-3
Beta 3 is better than beta 2. But you can't upgrade directly to beta 3 from beta 2, firstly you have to downgrade to .063 or .407 firmware then you can upgrade to the latest build. But if you directly upgrade from beta 2 there will be lots of bugs in your phone like many of the users are facing but if you upgrade from 063 firmware this update is really a better update.
I have .082 firmware . Will it be better to update to beta 3?
vishalsr098
bisukaisth097
https://zentalk.asus.com/en/discussion/comment/94259#Comment_94259
Yes, it will be better to update to beta 3 from 082 firmware.
And this latest 429 firmware is more stable than earlier firmwares e.g.,082,424, etc.
Y_ASUS
Zen Master I
saitejaakula
Do downgrading erasing all the data on phone?
Please share the link or provide steps to downgrade to android 9
Hi saitejaakula ,
Yes, downgrade will erase all data. You can find the downgrade file and instructions under "Version MaxProM1_downgrade_to_9" on our support site: https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB601KL)/HelpDesk_BIOS/
System downgrade will wipe all the personal data, please backup your important data before system downgrade.
Steps of Update:
1. Prepare a MicroSD card.
2. Check software version of your device**
3. Only apply to same SKU update, Example: WW->WW, CN->CN, TW->TW, ID->ID.
4. Software update cannot transfer the software SKU.
5. Wrong SKU may cause update failure, please update the same SKU version only.
6. How to manual update firmware please refer to
https://www.asus.com/support/FAQ/1042349
Y_ASUS
Zen Master I
saitejaakula
Hi saitejaakula,
Yes, you can update to WW-17.2017.2006.429 from WW-17.2017.2004.424. 🙂
