ASUS ZENFONE MAX PRO M1 087 BUILD NEW UPDATE
Im_Mukesh_Patel
Model Name:Asus Zenfone Max Pro M1
Firmware Version:087
Rooted or not:No
Frequency of Occurrence:
Asus Zenfone Max Pro M1 New Update 087,
ASUS system update
A new system update is provided to improve stability. This won't clear any of your data. Download it now?
16.2017.2009.087 (603.95 MB)
Download via mobile networks may incur extra fee. To download the update file, use Wi-Fi to avoid additional charges. You can also download the update file via Update Checking in Settings. You will be able to use your device during the download process.
5 September Security Patch in this Update... Aur Stability ko improve kiya gya hai
This Update is not available On Asus Website...
OTA Update Rolling Out...
Full Notification detail
https://bit.ly/3k2p9HO
Asus Zenfone Max Pro M1 087 Build update
15 REPLIES 15
Ratan
@Christine_ASUS , I want to know why enhance volte option missing in setting of my Vodafone sim. When I enter sim in other device its shows volte but in max pro m1 no volte option available. What should I do??
Yachendra
Rising Star II
Ratan
@Christine_ASUS
Check the screen shots in this and quoted posts.
Carrier name showing as "JIO" for other networks also. Check this bug. My internet is connected with Airtel but carrier shows Jio.
I already shared this bug in old Zentalk but no solution.
thegeralt1000
Rising Star I
Christine_ASUS
Hi thegeralt1000
Thank you for your asking. Once you unlock your device, the device will no longer be regarded as original product, recording as the unlock device by our server permanently. 🙏
Is there any solution for getting FOTA Updates in future and
razasaddam42
FOTA Updated दे के सब को फुसला रहें हैं Asus वाले ने Stable Updated version 10 देने में किया हो जाता हैं सब कम्पनी ने Stable Updated 10 दें रहें हैं Please Zenfone Max Pro M1 Stable Updated version 10 दिजये........!
After this update I can see VOwifi is back.
