05-27-2020 09:55 PM
08-06-2020 06:19 AM
mailtompmaniWait for 2 weeks, Again Battery drain issue ll happen. same symptoms of urs was for me.If Battery drain in idle not in switch off condition wait for any security update. If battery drain even in switch off condition better immediately change the battery. My battery drain in switch off mode around 20 days. Later battery become bulgy on edges and gape between the screen and panel. Then went to service center they said need to change the battery. july 29 they order the battery at the cost of 1800rs. then yesterday call me and come to change the battery. After battery replacement idle battery drain issue fully solved.
08-06-2020 07:53 PM
achuth24j00Battery drain not in switch off condition means battery is fine it's software issue. I think issue solve in next security update😐😐😐😑😑😑😑😑😑https://zentalk.asus.com/en/discussion/comment/101487#Comment_101487
Idle drain for one month in airplane mode also.
Then battery draining in switched off condition.
Then after one week battery bcm bulge and formed a gap b/w Screen and panel.
Then i too changed battery it costs 1800rs.
After changing the Battery for first 2 weeks it was going well.
Only maximum 1 % was draining at that time.
But after 2 weeks it is again draining.
But no draining in switched off condition.
I called service Center they told they want to check.
But my place is in lockdown.
I can't go outside now.
This software bugs made our Battery worse.
Very Bad from Asus.
They are not looking there update before publishing.
You must look ur update is working properly or not and after that you should publish.
🤦🏻:male_sign:😣😔😒
08-07-2020 04:03 AM
08-07-2020 04:26 AM
prithvi 2255Very disappoint with Asus 😐😐😐😐people who work in asus have no knowledge about the things happening in the mobile, they just want their users to keep paying them even if it is their mistake....
they said to me water log is there in the phone that is why the battery is having problems, all of a sudden after 1 year water will spawn inside the phone or what !
asus is the worst mobile phone company in india, i prefer a chineese branded phone over ASUS
08-07-2020 09:04 AM
rohitashva.dongre86Most indians kinda live in stone age.https://zentalk.asus.com/en/discussion/comment/100867#Comment_100867
India is a huge country, everyone does not live in metro cities. More than 85% of the population live in villages or small towns. So, are you referring that all 85% people live in a stone age???
