Asus Max Pro M1 Stable Android 10 Update Review with Screenshots...
roscheray101
Model Name: ZB601KL
Firmware Version: WW_Phone-17.2017.2004.424-2020.0414
Rooted or not: Not
Frequency of Occurrence:
I have just Downloaded and Installed the Android 10 update from the official site and these are some of the feedbacks.
The overall look has changed and it is very nice.
Miss the ambient display when there is a notification while the screen is locked which was there on earlier Android 9 version.
The flash light option on the taskbar is seemed kind of locked. Cannot be accessed. ( Issue solved by Restarting the phone)
The Dark mode works perfectly fine in all apps esp that of Google.
The new Boot animation has also changed and its good.
The Camera User Interface has also changed and it looks neat.
108 REPLIES 108
Facing lag in video while doing video call on 2hatsapp.... I also checked it with Duo and it works fine with duo ..... Issue only with WhatsApp
This asus zenfone max pro m1 do support native carrier video calling but the company somehow managed to make the option disappear through software update.... They can enable it in android 10 update.... the ringing volume is very low almost 50% that of pie version..... And i think the equaliser is somehow linked with this sound quality and volume problem....... Battery performance has been degraded if.you compare it with pie version........ The good point is all of these issues can be resolved with future software updates
das_souradip
Android 10 beta 2 version feedback reply
puneeth552
No don't update
It is worst
Less sound on speaker as compared to pie
Camera interface clean but it is buggy to take pictures.
Otherwise it is good
Asus Max Pro M1.
I have updated to android 10 two days back.
I'm facing the bluetooth problem with my wireless earphones. When I turned on and connect the wireless earphones, it connects and automatically bluetooth gets turned off. I tried even many times and after switch off and on phone the problem remains the same.
Help me to solve this problem.
