Asus Max Pro M1 Stable Android 10 Update Review with Screenshots...
roscheray101
Model Name: ZB601KL
Firmware Version: WW_Phone-17.2017.2004.424-2020.0414
Rooted or not: Not
Frequency of Occurrence:
I have just Downloaded and Installed the Android 10 update from the official site and these are some of the feedbacks.
The overall look has changed and it is very nice.
Miss the ambient display when there is a notification while the screen is locked which was there on earlier Android 9 version.
The flash light option on the taskbar is seemed kind of locked. Cannot be accessed. ( Issue solved by Restarting the phone)
The Dark mode works perfectly fine in all apps esp that of Google.
The new Boot animation has also changed and its good.
The Camera User Interface has also changed and it looks neat.
108 REPLIES 108
mayank_Avasthi
akhilas4121995
What about the official update.. is it jus like how we installed developer version or it 2ill come as fota update??
Will the developer version erase all the apps too??
Should i install developer version or should i wait for the stable version?? Please reply..
It will be better if you wait,the developer version (.424) does not remove apps it's like a normal update by it's full with bugs.
1st worst audio both earphone and speaker.
2nd battery drainage.
3rd multiple settings bug.
4th it's look like a forced theme application rather than android
I suggest that you shouldn't do that because rollback to 9 will cause data wipe so better stay where you are
mayank_Avasthi
Sushena
Headphone audio quality is garbage so I would like to downgrade to android pie , pls someone help me!
Just download the latest rollback provide on site, copy it on sd card use hard reset keys and apply update from sd card.
Backup data because it will cause data wipe.
Also when rollback you have to perform hard reset otherwise it will ask a "unknown" password.
mayank_Avasthi
sudhangsudaredevils
See my security patch also
You should not share this publicly.
Now go to asus site for max pro m1 and download update manually
Vyomesh03
Hey guys can someone give me the link to official site that has stable android 10 for max pro m1?
Vyomesh03
Vyomesh03
And also when will I get an fota update for the same?
