Asus max pro m1 android 10 beta RAW capture
nopitt7
Camera have RAW feature,but.....
Why i can't capture RAW image from stock camera asus zenfone max pro m1? Version android 10 beta 432 firmware.
This is bugs?
16 REPLIES 16
Christine_ASUS
Community Legend II
Hi friends
To investigate the case, kindly provide the information below so that we can better assist you.
1. Does the issue appear right after any system/apps' download or update?
2. Can you use the function in Android 9 or any firmware version before?
rumputliar30
Christine_ASUS
Hi friends
After more than 2 week, i have instagram ghost touch problem. Android 10 beta 432. Can you fix for next update?
Christine_ASUS
Community Legend II
Hi all
Thank you for your reply. Can you capture RAW format in Android 9?
arpand06
Christine_ASUS
Hi all
no raw capture is not available on android 9
nidhin3
Zen Master I
Christine_ASUS
Hi all
In the additional settings JPEG is set as default and we cannot change the format. Hence, RAW format is not supported in A9.
