Android 10 beta feedback of built number QKQ1.WW_Phone-17.2018.2004.424-20200506
Sir today i downloaded Android 10 beta  ( .424 ) version file from Asus website whose built number is:- QKQ1.WW_Phone-17.2018.2004.424-20200506 And i didn't get any issue regarding this update but have minor issues that i notice are:-
1- Battery need slight improvement
2- Camera quality is not good as Pie
3- we can't remove"Add another email"      option in settings
4- we also can't remove "Google search     bar" from home screen
5- Sometimes fingerprint is not unlocking properly
This is all about that i notices. This beta file need ABOVE improvement and Ready to release for STABLE Android 10 Roll out.
Hope you fix this soon...
5 REPLIES 5
nidhin3
Zen Master I
Bro, there are newer Android 10 beta builds available for your device. For even better system stability it would be better to install the latest update...
Also, most of the minor issues you mentioned are not bugs. They are normal AOSP behaviours.
Instalei o essa versão no max pro m2
ZB631KL e ficou horrivel! Meu celular tá com áudio e fone pessimos! Me ajudem o que eu faço?
ncapidosjr
Never lastest update Android 10
For pie 9 someone no experience
To how update my devices, no choice for everyone on risk device, if the best way Asus center or any manufacturer are mention google that update. And gives second chance for everything violated some cause not familiar for upgrade my phone, how to customer are actration in a buy in your gadget or loyal customer ?
bhelcpr
Zenfome Max M1 Pro OS 10 UPDATE...?
