0.60 BATTERY AND SYSTEM PERFORMANCE
techaseduardo
ZF Model: ZB602KL
RAM: 3G
Firmware/APP Version: 0.60
Frequency of Occurrence: Sempre
Rooted: No
APP Name:
O desempenho da bateria como um sistema inteiro permanece ideal. A duração da bateria é ótima e eu não uso o economizador de bateria. Eu acho que seria possível fazer mais horas de tela se não fosse o jogo que estou acostumado a jogar, que você sempre precisa de uma Internet fixa para ficar online.
4 REPLIES 4
zamri80
Battery so still drain 060 update..sound slow..sound ok 059
What about next update change log??? 🙂
techaseduardo
zamri80.mz posted on 2019/12/22 09:39 Battery so still drain 060 update..sound slow..sound ok 059
Waiting for a new one to correct that, which I find difficult.
ServiceH_ASUS
Hi techaseduardo Are you talking about battery drains in standby mode or in use? If you think that there’s battery draining in standby mode, please charge your phone to full before going to sleep, and leave it unused and unplugged overnight. Please capture 2 screenshots as below on the next morning before you use your phone and tell me how many percentages of power the phone has consumed overnight: 1. Battery: settings> Battery (Device usage since full charge) 2. Battery usage: settings> Battery> click the three dots > battery usage>show app usage Thank you for your inquiry. In order for us to help you with your situation, please kindly provide your information in English if possible. Thank you:)
