ZenFone 9 randomly restarts
HelpingHand
Rising Star I
Hi all,
I bought an Asus ZenFone 9 from the UK online store. I started to migrate the apps from my old phone to the zf9 and once I finished I started to use my new ZenFone 9 as my main phone. However, I noticed around 3 dso that when i wentato unplug a fter charging the phone it looked as if it has been restarted. I thought it was a software update that somehow just did that so I didn't pay attention but then it repeated again and again every day since.
I started paying attention to it and started trying to disable certain features to see if that made a difference: disabled mobile data, left everything on and now I'm on airplane mode with WiFi on.
I upgraded to the latest version that was pushed some days ago hoping that it would magically solve the issue but... it didn't!
I quick Google Search revealed that sadly this issue is not that uncommon, and has already happened in the UK and Germany to other ZenFone 9 owners.
Is this a hardware problem? Is there a fix or a patch other than simply perform a factory reset and keep seeing the same issue? Can please someone from Asus look into this issue?
Plehank youase tell us some basic information before asking for help:
Model Name: ZenFone 9
Firmware Version: WW_32.2040.2040.23
Rooted or not: no
Frequency of Occurrence: every day
APP Name & APP Version (If your issue relates to the app): not related to an app
Scenario: use the phone as usual, leave the phone idle a few times a day, at some point, when you try to use the phone after it sat idle for some time you'll notice that it had restarted because you'll be asked to enter your password again and about/ status will show an up time of just a few minutes
291 REPLIES 291
paweldejko
Hodor
The R&D team requires?!
Are you hearing yourself? There is obviously a real issue happening to probably ALL your Asus Zenfone 9 devices. Why don't the R&D team pick 1 device and test their work, it's only the minimum required from a developer. If you can't reproduce the issue it's obviously from laziness or incompetence, but leaving people with a new device that keep restarting is disrespectful to customers. I really want to like this phone and Asus as a company with great hardware but this is really not cool.
My Zenfone 9 has not restarted itself once since I picked it up at the end of August. Currently, the operating time is 265 hours and 16 minutes (over 11 days). I reset it manually on October 7 due to a malfunction of the LED Blinker application.
So, by all means, the problem may not be reproducible on a working device, and the claim that it occurs on ALL is an abuse when only a few users report it.
Ditko
Mansi_ASUS
For clarification purposes, the R&D team requires logs from users who happen to be experiencing this issue. You can upload the file to Google Drive and share its link with me via PM.
Please follow the given steps to enable the built-in log tool (Bug reporter).
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Note: When you're no longer planning on logging your device, enter “.09595+=” in the calculator and the log tool will stop as well as deleting all stored log files. Make sure to share via calculator. The files found in internal storage -> asus_log are not the correct files (they are only 1.2kb)
I can't pm as level one, would you mind sending me something so I can reply with my drive link?
Gosia
I've got the same issue, with the exception that today it happened when I was making a phone call. Until now, it didn't bother me that much because the only inconvenience was I needed to manually unlock my phone instead of using the finger print but now I would call it a serious flaw if the random reboot happens also whilst using the phone and not only when it's idle. Would love to see this issue resolved soon.
Zenfone9user
I have the same issue. Woke to my phone being restarted.
Dranivil
I have the same problem. I have already suffered 2 random reboots, one while charging the device and another while it was with the screen off without charging.
