ZenFone 9 randomly restarts
HelpingHand
Rising Star I
Hi all,
I bought an Asus ZenFone 9 from the UK online store. I started to migrate the apps from my old phone to the zf9 and once I finished I started to use my new ZenFone 9 as my main phone. However, I noticed around 3 dso that when i wentato unplug a fter charging the phone it looked as if it has been restarted. I thought it was a software update that somehow just did that so I didn't pay attention but then it repeated again and again every day since.
I started paying attention to it and started trying to disable certain features to see if that made a difference: disabled mobile data, left everything on and now I'm on airplane mode with WiFi on.
I upgraded to the latest version that was pushed some days ago hoping that it would magically solve the issue but... it didn't!
I quick Google Search revealed that sadly this issue is not that uncommon, and has already happened in the UK and Germany to other ZenFone 9 owners.
Is this a hardware problem? Is there a fix or a patch other than simply perform a factory reset and keep seeing the same issue? Can please someone from Asus look into this issue?
Plehank youase tell us some basic information before asking for help:
Model Name: ZenFone 9
Firmware Version: WW_32.2040.2040.23
Rooted or not: no
Frequency of Occurrence: every day
APP Name & APP Version (If your issue relates to the app): not related to an app
Scenario: use the phone as usual, leave the phone idle a few times a day, at some point, when you try to use the phone after it sat idle for some time you'll notice that it had restarted because you'll be asked to enter your password again and about/ status will show an up time of just a few minutes
291 REPLIES 291
Hodor
I found several posts also saying that it is causing this behavior though on Galaxy phones https://forum.xda-developers.com/t/reboots-shutdowns-w-fingerprint-scanner.3856346/
Ditko
Has there been any updates from ASUS regarding this issue? I got my Z9 Saturday and started to experience random restarts yesterday. I've logged the restarts happening a few times but I'm unsure of how to send the files to mods here.
Mansi_ASUS
For clarification purposes, the R&D team requires logs from users who happen to be experiencing this issue. You can upload the file to Google Drive and share its link with me via PM.
Please follow the given steps to enable the built-in log tool (Bug reporter).
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Note: When you're no longer planning on logging your device, enter “.09595+=” in the calculator and the log tool will stop as well as deleting all stored log files. Make sure to share via calculator. The files found in internal storage -> asus_log are not the correct files (they are only 1.2kb)
Hodor
The R&D team requires?!
Are you hearing yourself? There is obviously a real issue happening to probably ALL your Asus Zenfone 9 devices. Why don't the R&D team pick 1 device and test their work, it's only the minimum required from a developer. If you can't reproduce the issue it's obviously from laziness or incompetence, but leaving people with a new device that keep restarting is disrespectful to customers. I really want to like this phone and Asus as a company with great hardware but this is really not cool.
jeremy6652
There is no way to debug this without logs. It's not happening to everyone and there are no clear steps to reproduce this so a log is the only way to figure out what's happening.
