12-16-2023 01:50 AM
12-16-2023 02:03 AM
I've just acquired a new zenfone 9. I've noticed the battery percentage reading started dropping quite quickly after an hour or so of general usage, scrolling the screen. I have been using zenfone phones and several models for many years. This battery draining is almost similar to my 5 years old zenfone 4
12-18-2023 04:54 AM
Hey @mealone43,
Can you please share a log file?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
