Zenfone 9 Battery Drain by "Others"
bLackShadow7
Hello,
I have just bought a Zenfone 9 last week and I am having bad battery life. The SOT is roughly 3 to 4 hours. I can see most of the battery is consuming by "Others".
Is it normal?
Model Name: Zenfone 9
Firmware Version: 32.2050.2050.34
I am really disappointed with the battery performance so far.
Thank you
97 REPLIES 97
pequinois44
moi j'ai remarqué quelques fois une consommation excessive par Google play services sans diminuer énormément pour autant l'autonomie de la batterie. cela est aléatoire et se règle apparemment avec les mises à jour successives de cette application Google.
Homann
@Mansi_ASUS yes. Right now I am at 25% "others".
Homann
@Mansi_ASUS and by end of day with 13% left i have 47% others:
Mansi_ASUS
Hey @Homann,
I reported the issue to R&D and as per their reply, the team would need a log file from your end.
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
You can share the file with me via PM.
valetechg
Hey folks,
I've the same behaviour on my end. Close to 30% "Others" usage (from 100% to 50% drop). See attached image below.
Would be awesome to have an official response here about this issue.
@Mansi_ASUS I could assist with whatever is needed, however I need more details - do I need to let the battery drain for some time before 'finishing' the log file (so it can gather data) or I can just start & finish it instantly and the log files will contain the needed information? My concern is that it might not be too useful in debugging the bottleneck here.
Regards, Valetech
