Zenfone 9 Android 14 audio issues
bramhast
So I just received the Android 14 update for my Zenfone 9. Everything works ok aside from certain sound effects, most notably the screen locking / unlocking sound (the default snap and camera shutter sounds), and also the sound that plays when you plug the phone into a charger is missing.
I can get these to work again by changing my audio state e.g. to vibrate and then back to normal. However, the sound effects sound muffled / lower quality than usual. I've tried restarting the phone three times already but it doesn't seem to help. After each reboot, the sounds are gone again. Sound for media apps like Spotify etc. work fine, though.
Anyone else with the same issues?
6 REPLIES 6
One more: after tapping on notification, there's a ~1 sec. gap before app opens.
Sometimes, gesture "Home" needs to be repeated.
