Zenfone 9 Android 14 audio issues
bramhast
So I just received the Android 14 update for my Zenfone 9. Everything works ok aside from certain sound effects, most notably the screen locking / unlocking sound (the default snap and camera shutter sounds), and also the sound that plays when you plug the phone into a charger is missing.
I can get these to work again by changing my audio state e.g. to vibrate and then back to normal. However, the sound effects sound muffled / lower quality than usual. I've tried restarting the phone three times already but it doesn't seem to help. After each reboot, the sounds are gone again. Sound for media apps like Spotify etc. work fine, though.
Anyone else with the same issues?
6 REPLIES 6
Bazuark
Same for me
today I installed the new update with Android 14 on my Zenfone 9, unfortunately both the notification sounds and the ringtone music are monophonic, very low quality and at lower volume
Adrian82
Rising Star I
Same issue here.
After update to A14, the speaker not balance. Top speaker louder than bottom speaker,  notification sounds like mono speaker and sound quality not good as on A13
Mansi_ASUS
Hey,
The R&D couldn't recreate the issue. Can you please provide a log along with a video recording of the issue?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Kuntso_Maksym
I have the same issue. Plus, the interface is a little clunky.
