Zenfone 9 android 13 bugs
louren180
Using zenfone 9 to 2 months. The list of bugs after the update keeps growing.
1 - I had to disable the always-on screen, because it keeps turning on and off all the time. Even with the device on a stationary table. So whenever new messages come in I have to pick up the phone to see what it is about.
2 - I can't turn off the notification sounds through the quick menu, I have to go into the settings and lower the volume, just putting it on vibrate turns off all sounds, including the songs playing on spotify.
3 - Speaker mode on call, I can't hear who is talking. Need to call again and already activate the speaker to be able to hear who speaks.
4 - Some apps do not work as they should. Nike Run for example, even after being closed it continued to work in my pocket for 4 days, whenever I walked and stopped it vibrated, until I opened the app again and finished an exercise I had done. The app has been closed for days.
5 - I did some resets on the device to correct normal operation several times. I don't see this as normal on such a new device.
I've never had similar problems on other android devices. I used google pixel 4a and I still have it as a spare device, and not even on the zflip 3 that I replace with the zenfone 9.
The list of bugs is longer, but I don't remember the rest now. The device itself is great, 16gb of ram and 256gb of memory, very good screen and long battery life. I have nothing to complain about the hardware, only the software needs improvement. However, there are complaints that interfere with my use and I have to adapt to be able to use it. For that alone, he already lost points with me.
5 REPLIES 5
ZenBot
Community Manager
Community Manager
