Sound fluctuates
haraldgimse
General information:
Model Name: Zenfone 9
Firmware Version: Newest
Rooted or not: Not Rooted
Frequency of Occurrence: All the time, random time between.
Spotify and YouTube (probably others too, only ones im using)
My Sound fluctuates up and down randomly while using any app that uses sounds, also when both using BT Headphones and the built in speakers. The only way to make the sound go back normal is to use the volume controls.
It happens all the time, sometimes there is 15 secs between sometimes longer.. its extremely infuriating to deal with..
Im not using outdoor mode, it happens both with Classic and ASUS music modes, it also happens on all 4 settings (Dynamic, Music, Gaming ..)
4 REPLIES 4
Mansi_ASUS
Hey @haraldgimse, I'll be forwarding the issue to the R&D team. Can you please share your FW version?
haraldgimse
Mansi_ASUS
Hi, thanks.
Its WW_32.2040.2040.23
Ive had the phone for about a week..
Mansi_ASUS
Hey @haraldgimse!
I heard back from the R&D team, they need to clarify the following-
When the problem occurs, does the Audio Wizard show that it cannot be enabled?
Can you also share the music clip or audio file with the time when this issue generally occurs?
Does the issue persist even with the latest FW update?
Also, to analyze the issue, can you please share the log file?
You can use the following steps to enable the log tool-
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “Sound, call audio, and recording”
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
ASUS_Bot
Rising Star II
