Broken and crackling sound with lossless codec
arek2
Hi Community,
I bought Senheiser Momentum 4, especially to use the APTx lossless codec. However I can't use it, as after several seconds one of the channel starts emmit breaking and crackling sound. With APTx adaptive everything is fine. Software is up to date in all devices. The soft is WW_34.1004.0204.201
Can somebody help me? Thank you in advance 🙂
jankomo
Hi arek2. I have exactly the same problem, also with Sennheiser Momentum. I brought it to Asus and Sennheiser's attention a few months ago. They always blame the other. Both devices are probably not fully developed or don't work well together. Unfortunately, I don't have another mobile to compare that supports apxt lossless. But like you, everything works without a problem with aptx adaptive. Unfortunately, I don't know what to do and have already considered sending the phone in for repair, but that probably won't help. Do you have a solution now?
