Big issue with Bluetooth car connection
ogio81
I have issues with using Zenfone 9 with my Volvo XC60 (2017). Mo phone sometimes connect with car, sometimes I must do manually, I didn't have same issues with Xiaomi or iPhone or Samsung phonesde when I make call from car inferface, dialing after couple of seconds is canceled, if I start call from mobile, then is going okb I notice in interface of phone "Bluetooth screen", that mode of connection lwith car is jumping from Media to Other Nlease I need help, I need this to work, like all other phones, I suppose issue is with Zenfone because other phones work without any problems.
Device
: Zenfone 9
Firmware Version:
Rooted or not: no
Frequency of Occurrence: Always
APP Name & APP Version (If your issue relates to the app): System bluetooth
7 REPLIES 7
MrAvenger
Rising Star II
Same issue with toyota rav4
Mansi_ASUS
Hey @ogio81,
Can you please share the Bluetooth log? It'll help the R&D to figure out the issue.
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “Bluetooth”
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
ZenBot
Community Manager
Community Manager
