03-12-2023 07:28 PM
Hi all, as the subject mentioned.
Did anyone encounter the same issue?
I use hotpost most of the time, and it become annoying now as it happen too often.
When my Zenfone 8 hotspot is activated. It always suddenly force restart when there is change in wifi status. For example, when I have one connected device in my hotspot, if wifi toggle change from on to off or I suddenly get connected to a wifi router, my phone will restart.
I think this is a software issue where Asus need to fix.
I'm running on latest Asus firmware, non-root.
03-14-2023 08:27 PM
Hi @trtshen ,
according to your problem, please refer to the following FAQ to try to troubleshoot your Wi-Fi problem first.
https://www.asus.com/support/faq/1006657/
Also, I have PM you for confirming Wi-Fi issue details.
Could you please check the PM inbox at the top right corner of the screen and kindly provide the requested information?
