wifi not work zenfone 8 after android 13 upgrade
beresyit
exactly 1 year of using asus zenfone 8 suddenly wifi doesn't work, hotspot doesn't work, and GPS doesn't work properly. all this started when I upgraded to android 13.
the warranty has ended suddenly an event like this happened. can I get an additional warranty?
previously I never experienced problems while using android 12
83 REPLIES 83
Can I get free replacement for this issue from SG
Hi @Lololol ,
We apologize for any inconvenience this may cause.
Please check the top right corner and kindly share the serial number and details requested in the PM inbox.
Thank you!
Kokotei08
Is there a solution to this? My phone suddenly have this problem too
Hi @Kokotei08 ,
sorry for the inconvenience that may caused.
We have sent you a messege.
Thank you!
I doubt they have a solution. Mine has been like that for a month or so now. The "solution" they present here is a link to a FAQ which 100% wont solve it, and a PM telling you to send it to a repair center.
