Headphones jack problem
Toni0407
When I make calls with the headphones jack the device (ASUS 😎 shuts off after about 1 minute. I tried with different numbers and headphones jacks but it is always the same.
4 REPLIES 4
DroidFIN
This issues has been reported here time to time (see from below). BTW, are you using VoLTE during these calls?
https://zentalk.asus.com/en/discussion/51487/headphones-with-microphone-issue
Toni0407
Thanks for getting back to me.
Sorry, What is Volte?
Also I could not find anything useful in the link you provided, probably I missed something? Is there a solution of do I have to leave the device to experts so that they can fix it ??
Toni0407
DroidFIN
Oh thanks,
Yes I am using it. What would you suggest?
Thanks again for your time.
DroidFIN
Toni0407
https://zentalk.asus.com/en/discussion/comment/200481#Comment_200481
Oh thanks,
Maybe you could disable VoLTE and check if that helps with situation? I have not faced this issue but my operator does not support VoLTE for ZenFone 8. Might not be related but who knows?
