06-13-2021 02:21 AM
07-09-2021 09:13 AM
ElmirIt can be an app, pulling data or pinging because it has internet (that would happen on wifi also) but we cant rule out some bug or network related issue.So mine just used 2.7% in 56 mins for mobile network standby. I have set it to 2g/3g only before taking it off the charger. Not sure what is happening to be honest.
07-09-2021 10:53 PM
07-10-2021 02:51 AM
07-10-2021 02:43 PM
ElmirBeen struggling with cell standby battery drain since day 1, i'm my case i found that scheduled power saving was one of the causes. I'm also going to try your suggestion and see if it works for me too, i'll keep you posted.Also I think I found the cause in my case. I disabled the "adaptive battery" and background app management and this is the usage now:
This is MUCH better. If you would like to debug this I would be glad to. Now I regret turning this on 5-6 days ago. I just couldn't correlate mobile network standby drain with these two things. They are supposed to prevent drain.
07-11-2021 12:44 AM
