Battery Stats
soulflywalker
Hello Guys,
Sicnce 3 weeks I have Zenfone 8flip. I dedicated this time to elongate battery life. As I'm pretty happy from what I've achieved, however strange thing happened. In battery stats there is no phone calls. It just suddenly vanished, but I'm still calling a lot. Any ideas what's going on? Attached stats before and now.
12 REPLIES 12
raimundas78
Rising Star I
jakislogin2
Same here on Zenfone 8. I think that started with update 115
It changed with previous update, there was known Mobile Network Standby battery drain issue, which they 'fixed'. However, battery life did not change a bit, seems just that drain is not show under that task anymore.
soulflywalker
Thanks for support.
Strange topic. If connected with standby why they get rid of real calling stats.
Anyway have you found some tips how to improove battery lasting per charge?
My previous Mi 9T with smaller battery have simillar performance.
daniel91m
Rising Star II
ZENFONE 8 should be called a landline phone.
1. Only one location and wifi the time (lazy sunday)
2. 50/50 wifi and LTE (normal working day)
Is it normal?
Blumi
Rising Star II
daniel91m
Is it normal?
Have you tried resetting the charge indicator? When did it go off? For me I often experience around 1 hour at one percent - even with dynamic system mode. Please check the xda accubattery readings:
https://forum.xda-developers.com/t/accubattery-capacity-readings.4325995/
