Battery Replacement
Viper555
I want to ask if anyone replaced battery in Zenfone 8? How to get original one. I live in Poland and as I searched for battery availability it doesn't look good. When I had a Huawei phone it was the manufacturer at authorized service centers that did battery replacement campaigns for a small amount of money, is there such a thing in Asus too?
After 2 years without replacing the battery this phone becomes useless...
6 REPLIES 6
tochmi
Zen Master I
That Huawei battery replacement campaign was because its batteries had a defect. And when it happened to me, they changed it for free after 3 years of use (in Spain).
As far as is known, the batteries that Asus has mounted have a normal operation and there is no replacement campaign. Talk to Asus support in Poland and get a quote.
Falcon_ASUS
@Viper555
You may contact the local customer service to inquire about sending it for battery replacement.
The following is the contact information: https://www.asus.com/support/CallUs#
Thanks a lot, I hope this doesn't mean that they got only 1 item 😂 Unfortunately it's a little expensive, 47 e with ship to Poland ;/
  • Stock status:  1 In stock
