05-29-2021
11:52 AM
- last edited on
01-16-2024
01:48 AM
by
ZenBot
05-30-2021 01:24 AM
mkumitsuI dont know what you know about battery tech. And this is for the reason.they refer to the charge at 95℅= min And then 100℅= typical. As per the advanced BMS/charging-safety of a mobile phone, they will reach min first then typical with a lot of time taking, that's why they mentioned in that manner.But in most cases, it will applicable by advanced BMS or Charging system involved.https://zentalk.asus.com/en/discussion/comment/169060#Comment_169060
No, it's not normal. Capacity should be as producent declared. And is in Sony of even Xiaomi. Samsung for example limit full charge to about 94%, but they at least inform you about it. I would like to use full capacity and that's why I bought phone with big battery.
U7G7hbI just tested my Zenfone 8, which has now been charged 3 times.
For reference, this is from a Sony Xperia 5 II that has been used for 7 months:
So in my case, it definitely seems low.
mkumitsuAccubattery is not an accurate app. It keeps on varying mah on number of charge cycles. Trusting it to full fledge is not acceptable. You can google to know what's the reason behind such battery tech for smartphones.Hi, Did anyone check the battery capacity of his ZenFone 8? My is barely 3600mah and I wonder if something is wrong with my battery or the capacity is smaller then Asus assured.
Battery capacity
05-30-2021 03:15 AM
05-30-2021 06:33 AM
05-30-2021 01:27 PM
