Hello, I have found small issue. When I plug 3,5mm jack from dedicated amplifier the audio creator witch graphical corrector, bass, treble etc. doesn't work. It only work when i plug typical earphones or headphones. You can see this on movie below - audio device is always reognized, but only earphones are recognized in audio creator:
(remove spaces next to dot)
youtu . be/2APp9U2-oUM
I tried also a hack - plugged earphones to splitter, then splitter to phone, then unplugged earphones from splitter and plugged amplifier. After this creator is working properly, music quality is good and changes in corector are audible imidiately. Obviusly this work till splitter is plugged, after unplug I have to do this again.
It looks like phone is configured to block audio creator when recognizes too high impedance on input - when i plug splitter alone it's also locked. Somebody can check this? I think it schouldn't work like that, I'm even 95% sure that it worked properly first time when i took phone from box, maybe something changed after first update.
