01-27-2023 12:41 PM
Hello,
I updated manually to Android 13. So far there are no issues, it is stable.
But what happened to the Battery - System modes - "Advanced system mode"?
It was giving the user a lot of control and was a great option. Why Asus decided to remove it?
Now I'm stuck with "Dynamic" mode where the battery life is garbage or "Durable" mode where there is no background sync.
Before the update I was able to make a very balanced custom profile and normally was getting 2 days of battery life without compromising on functionality.
Do the Asus Team plans to add back the Advanced system mode in the future updates?
02-06-2023 03:32 PM
Hi @Iceman11 Iceman
Advance mode is no longer available, however, you can select any of the new system modes and you can adjust the settings to what you prefer by using the gear icon.
Thanks!
02-14-2023 10:49 PM - edited 02-14-2023 10:50 PM
Hi @keren_ASUS ,
When i want to adjust there are no flexibility like old advance mode, removing advance mode more like a major problem, now i cannot use my phone for a whole day(battery run out very quick), please return the old advance mode.
The advance mode is one reason i chose Asus Zenfone 8, please don't down grade my phone software quality.
Best Regards
3 weeks ago
No, we could NOT adjust the system mode as in the advanced mode: no CPU adjustment etc. !!!!!!
02-28-2023 01:49 PM
I agree losing advanced mode sucks. The new modes offer nowhere near the flexibility. I have to choose between short battery life, missing background notifications, or unknown let us drive mode.
I used to be able to choose keeping the phone awake and usable but turning down CPU and memory performance to save the battery.
