Flip camera tool shortcut does not work
lf_asus_z7p
Model Name: zenfone 7 pro
Firmware Version: 29.13.7.47
Rooted or not: not rooted
Frequency of Occurrence: every time
Video attached
When using the flip camera tool swipe up shortcut, it does not show up
6 REPLIES 6
Anders_ASUS
Hall of Fame III
lf.asus.z7p
  1. Model Name: zenfone 7 pro
  2. Firmware Version: 29.13.7.47
  3. Rooted or not: not rooted
  4. Frequency of Occurrence: every time
Video attached
https://us.v-cdn.net/6031231/uploads/JTBISARGG163/2020-11-05-23-21-31.mp4
You must swipe in from the very edge of the corner. It's hard to see from your video if you're doing it right or if you're a little bit too far off to the left. I can send you a PM with you want to send a log
lf_asus_z7p
I just solved the problem however i think this was not a normal behavior of the system. This swipe up gesture shortcut actually does not work when i disable google as device assistant.
I dont like it because when i try to record an audio message within whatsapp i always accidentally touch the assistant zone activation in the navbar ( right side corner).
So why asus flip camera tool swipe gesture is broken when device assistant is disabled ?
Anders_ASUS
Hall of Fame III
lf.asus.z7p
Thanks!
Anders_ASUS
Hall of Fame III
I'd just like to update that this will be fixed in a future FOTA. Thanks!
