04-20-2021 03:56 AM
05-05-2021 03:51 PM
05-05-2021 05:58 PM
skipwoofCool so I'm not going nuts it is a problem I was starting to think that maybe it was the same on A10,at my age the memory isn't what it used to be. I will uninstall all the updates now and see how it goes today. Thanks heaps for your help you are the only person who actually listened to what I was saying and came up with a fix even if it does mean taking a step back on the calendar app but I prefer to live with that then no notification from reminders. Hopefully Asus will come up with a fix in the next update RGDS RoyOk, according to this old post : www.reddit[.]com/r/GooglePixel/comments/a3edwu/google_reminders_not_working_i_may_have_a_fix/ (I'm not allowed to post links)
If we remove the updates of the application, it fix the issue for the reminder. I tried, and... exact, it solves the issue. Notifications are back.
Updating the application via Play Store to latest version will bring back the bug.
Anyway, issue occurs only with ZenFone, so... 💁♂️
05-05-2021 06:02 PM
skipwoofSo far so good just got both a visual and audio notification from a test reminder 😉 your the man,man👍Ok, according to this old post : www.reddit[.]com/r/GooglePixel/comments/a3edwu/google_reminders_not_working_i_may_have_a_fix/ (I'm not allowed to post links)
05-05-2021 06:20 PM
skipwoofThat's a bit strange,I don't claim to know much about smartphones or zenfones but it is confusing isn't it ? As you kindly said uninstalling the calendar updates works so as it is a Google app you would think that the problem lay with the playstore but it works on your Nokia A11 so that puts the bug fairly in zenfones lap hmmmm, stay tuned I supposeOk, according to this old post : www.reddit[.]com/r/GooglePixel/comments/a3edwu/google_reminders_not_working_i_may_have_a_fix/ (I'm not allowed to post links)
05-06-2021 07:30 AM
