04-20-2021 03:56 AM
05-11-2021 01:52 AM
05-11-2021 01:57 AM
05-11-2021 02:55 AM
fear_dot_com_2000exactly!! I've reported that in the BETA alreadyAs I said before...I see a lot of issues lately with A11 and I think the root cause is somewhere else. I have checked and double checked and triple checked all the settings, even factory reset the phone many times, this appear to come from the way apps are killed (or dozed ). Something in A11 is preventing apps to refresh.
I have stopped all the battery optimizations and the issues are still there. The whether widget for instance is not refreshing as well on the screen unless I go directly in the app. And like this there are a lot of apps that do nothing until you open that app.
And the steps that were provided should be used mostly as a workaround and not as fix. I checked my wife's pixel 3a and all apps are optimized and she has no issues whatsoever. The issue lies somewhere in the A11 code for Zenfone 7. What I have now were the same on A10 and everything was working fine. Since A11 update I missed emails, calendar notifications, instagram notifications, sometime bank apps don't send notifications, whether app widget is not updating and for sure I think that if there is an app that is supposed to work in background and send notifications it won't work....
Battery optimizations are there to make thinks optimized ( work in background and not eat to much battery ) but even with that disabled some things are not working. But even so disabling battery optimizations should not be a solution but a workaround as I said.
And I am sure that the calendar problem happens to all users , so I think the devs should reproduce it easily, but are either incompetent or working on something else for now ( maybe a new phone release?! Just saying...)
05-11-2021 03:07 AM
05-12-2021 05:39 AM
RoystoysI believe the Google Calendar reminder is a different/separate issue and it should be easy to find/fix as I'm able to replicate it on both ZF6 and ZF7. ZF8 and allt the ROG phones i tried does not have this bug.https://zentalk.asus.com/en/discussion/comment/166380#Comment_166380
The only problem I personally have is with the calendar app
If you set a reminder you don't get any notification at all, you do if you set a task or a goal but not for reminders. As stated above by, Skipwoof,if you uninstall the updates for the app you get alerts for reminders but as soon as you update it again you stop getting notifications.
It sounds like a Google app bug but Skipwoof pointed out that it works fine on A11 with a Nokia phone so it is just confusing???
I just purchased a Nokia g 10 for my wife so I will be able to see first hand what's what, once it arrives ( about a week or so.
Having said that there are problems with notifications on A11 so many people are having issues. I have one with a notification on the pull down drape with, driving mode, . For some reason sometimes after using Google maps while connected to my van I get a notification on the drape saying, driving mode tap to exit,or something like that but if you tap exit driving mode the notification just stays there until you restart the phone. Bizarre as it is only happens sometimes
fear_dot_com_2000Have you given the weather app permission to auto update (every 30min-12h)? You do this inside the appAs I said before...I see a lot of issues lately with A11 and I think the root cause is somewhere else. I have checked and double checked and triple checked all the settings, even factory reset the phone many times, this appear to come from the way apps are killed (or dozed ). Something in A11 is preventing apps to refresh.
