10-09-2019 03:53 AM
10-23-2019 04:06 AM
TegliThe headset has arrived. Although is is very disappointing. Volume is low even if outdoors mode switched on. Bass does not exist. Sound is like an old Soviet Sokol radio.
Any suggestion?
10-24-2019 03:53 PM
10-29-2019 03:21 AM
cobbenThanks! AAC is definitely a big quality jump. I will keep playing around with settings. Indoor quality and volume is acceptable now. Will test outdoors later.https://zentalk.asus.com/en/discussion/comment/22845#Comment_22845
Mine are working fine, and loud enough without putting the volume on max.
You should switch the BT codec from SBC to AAC in the developer settings, that improves the sound quality a lot.
Then you should look in the Audio Wizard, and check any equalizer in whatever player app you are using, so that does not conflict with Asus Audio Wizard.
