Timer not resetting bug/issue
alique01
Hello,
I have noticed an issue with the clock app. When you set a timer, and the timer is up, a screen comes up stating that the timer is up and you have an option to click ok. If you click ok, the timer does not reset in the clock application. It just shows you how many seconds it took you to dismiss it. This is getting annoying, because after a while, you end up with a bunch of negative timers in the timer app and in order to use them, you must first click "reset".
I honestly don't see why dismissing the timer just pauses it instead of resetting it and why it was programmed this way. May just be a bug.
6 REPLIES 6
alique01
_jis_
So why don't you use Google Clock?
I prefer to use the stock clock application and would like to suggest improvements to it.
In any case, I do not believe this is normal behavior for a timer. Do you know of any other timer that shows the seconds it took you to dismiss it instead of just resetting once you dismiss it? If it was a pause button that would be another case, but there is just an "ok" button.
_jis_
Zen Master III
That's your decision, I prefer to use app which suits my needs better right now and not fixed one maybe sometime in the future.
It is perfectly fine and thanks for that.
