12-10-2019
08:48 AM
- last edited on
01-16-2024
01:37 AM
by
ZenBot
Solved! Go to Solution.
01-09-2020 11:34 AM
01-10-2020 06:58 AM
_jis_How you are hiding navigation bar?Exactly, Thank you.
As a workaround I wanted to use a Smart key but to my surprise Quick settings is not available at all. The Smart key is so limited it is all the way to cry.
Thankfully, I have been using the brilliant FNG application since Pie, where I solved it with another gesture.
https://play.google.com/store/apps/details?id=com.fb.fluid
01-10-2020 08:11 AM
02-27-2020 08:23 AM
_jis_I noticed that gesture to expand Quick Settings acts just as gesture to expand Notifications after update to .129.
Can anyone confirm this?
I noticed this behaviour in two different applications Nova launcher and Fluid Navigation Gestures so it is not an app fault, it is a system level issue.
Nova - the last one gesture on this screenshot
FNG - the first one gesture on this screenshot
Crippled gesture to expand Quick Settings after .129 update
