Tap a notification and the phone locks itself.
Supra
Rising Star I
WW-17.1810.1911.110
Lawnchair launcher
Happens once every few days. I'll get a notification, tap it, then my screen will go black and I'll be on the lock screen. Happens most often with Google Messages. Anyone having this problem?
30 REPLIES 30
baster1982
Rising Star II
Confirm that it's still happens on WW_17.1810.2001.121
baster1982
Rising Star II
Also in update .129 not fix
_jis_
Zen Master III
Users here reported this issue with Lawnchair launcher and stock launcher.
I am using Nova launcher and I had double tap to lock enabled (since January 20 to test it, but I don't actively use this double tap, because I am using another gesture to turn my phone off) and never have been experienced such a behaviour as is described in OP with 119, 121, 129.
baster1982
Rising Star II
I using adw launcher 2 and the same happens
_jis_
Zen Master III
I wonder what you, who are affected by this issue, have in common. It would be good if you go through this thread again and poke the one thing you have probably set up and that is the cause.
The error will then be eliminated more quickly and easily.
