Speaker/Earpiece volume/camera issue
Krishna99
 I just bought Zenfone 6Z and also updated same with latest version. Quality of Camera/Earpiece volume/very cheap Sound quality are the biggest issue i am facing. Kindly give me solution asap so wouldnt be regrating my choice buying 6Z.
ColorSage
Zen Master I
I have no problem with camera quality. Earpiece is also ok to me. Bottom speaker's basic settings are not great but you can easily alter it to your liking in DTS app. Then it can sound much better.
Krishna99
Appriciate your suggestions but it really sound cheap.. My zenfone 3 quality was much beeter than this one.
alexalbert03
Rising Star I
VS-KR
Your perception of sounds is not the same as someone else.
In my mind, I find these speakers really correct when you personalize AudioWizard.
I agree with VS-KR , after tweeking with audio wizard much to pleasure I was satisfied . Sounds are very crisp and clear with enough beat to them. Earpiece quality is an entire different thread though.
