07-30-2019 09:02 PM
08-06-2019 12:49 PM
Ah, you found a workaround so we don't need to fix it xDprashanthreddy.mukku said:I wanted to screen record when the issue came but as soon as i drag down notification panel to look for screen recorder it worksAnders_ASUS said:Are you saying that the quick button four vibrate mode in the quick setting menu is not working unless you press it 2-3 times? Is it possible for you to capture this with the built in screen recorder and post it here? Are you on the latest FW?
I just emailed our developers to hear what the latest status is regarding auto rotate.
