Immense battery drain!
johnCforVTS
Rising Star I
Hi, the last couple af days its really a downhill for my device, other than the fact that my camera doesnt flip at all, and i am planning to visit asus sevice center the next days...battery started to drain like crazy too. And i am using the device wayy less in comparison with other days. I fall asleep with 80 and i woke up with 40%. Nothing has changed yet i am in a constant hurry to charge my phone which by the way is charging way slower than it used to!
Anyone else something similar?
Thanks in advance
25 REPLIES 25
b4n4n4p4nd4
Is there a way to add an external antenna to the 3.5mm audio jack or the usb-c port on the zenfone5z to achieve a signal gain? I'm temporarily in an area where I'm so far from the nearest tower that I have maybe 2% time in 4g, 65% time with HSPA+ at about 1 bar (-115db), and the rest of the time I think it gets 3g. I can sms from here just fine and occasionally I can load a web page, but the latency is about 2000-3000ms which effectively stops certain apps from functioning. I wouldn't mind being on a slower data rate as long as the latency on the apps could improve to being functional.
