High temperature battery stops quick charging
Giorgio80
I received a notification that charging was stopped cause of high temperature of the battery .. This is the second time it happened ... I wasnt using the smartphone while charging ...
Anders_ASUS
Hall of Fame III
We have removed this message with newer firmware. Please update your phone.
Giorgio80
Ok but the smartphone stops charging with this message
Anders_ASUS
Hall of Fame III
can you please install an app like CPU Monitor and tell me 1 what your temperature is in the room and 2 what the temperature is of the battery.
You may not use your phone while fast charging. Light use like reading messages is fine but not gaming or videos.
I also like to know how long it take before it stops charging
Thanks!
