Help!!! Camera problem. Can anyone help?
pokiese7en
8 REPLIES 8
_jis_
Zen Master III
Did you try to "Restore default settings" in Camera Settings?
Did you try to Clear storage for Camera app?
pokiese7en
yes tried all this, it is still the same
_jis_
Zen Master III
Then service your phone, because it is a HW fault.
mastervishikh
Rising Star I
Is this happening in all applications which use camera or just the camera app.
Try using camera from snapchat or Instagram apps and check. If there also same results probably hardware problem. If it works there properly try factory reset
