07-09-2019 06:29 AM - last edited on 01-16-2024 12:00 AM by ZenBot
07-11-2019 03:25 AM
07-11-2019 04:39 AM
Sounds like a bug, caused by something in which was previously installed on your phone. If one more person report this issue, then we will look into it. You issue will hopefully get fixed with the next update but you could also factory reset your phone if you can't wait. Make a backup first. It will save you a lot of time.kinguntas23 said:Am I the only one having this issue that if I click a photo from the front camera on portrait mode on the Zenfone 6, I just cannot edit it (Change focus, Blur intensity). All I see is a green screen. The portrait mode was working very fine. I manually downloaded the the latest FOTA update (The one with 8x digital zoom) and this issue popped up. The back camera portrait is fine, only the front camera is messed up.
So am I the only one having this problem?
07-11-2019 04:56 AM
Anders_ASUS said:Sounds like a bug, caused by something in which was previously installed on your phone. If one more person report this issue, then we will look into it. You issue will hopefully get fixed with the next update but you could also factory reset your phone if you can't wait. Make a backup first. It will save you a lot of time.kinguntas23 said:Am I the only one having this issue that if I click a photo from the front camera on portrait mode on the Zenfone 6, I just cannot edit it (Change focus, Blur intensity). All I see is a green screen. The portrait mode was working very fine. I manually downloaded the the latest FOTA update (The one with 8x digital zoom) and this issue popped up. The back camera portrait is fine, only the front camera is messed up.
07-11-2019 06:22 AM
