Bright photos and Battery life
coderedcomputin
Using Gallery all my photos appear normal.  When looking at the same photos in Google Photos the picture appears normal for a second then brightness increases dramatically and washes out the photo.  Any settings that I need to change or is this a soon to be addressed software glitch?
Phone has been used for 1 week now.  AccuBattery is showing it is only at 91% estimated health with only 4571mAh available.  So, is this actually a 5000mAh battery here or ?
11 REPLIES 11
_jis_
Zen Master III
1) See this thread: https://zentalk.asus.com/en/discussion/9111/issue-on-photos-application
2) You should use AccuBattery at least for a few weeks to get better estimation of your battery capacity. I am getting 95% 4768 mAh after 62 days of usage. BTW rated capacity is 4850 mAh.
youtu.be/d58neQ6Ewho?t=109
https://youtu.be/d58neQ6Ewho?t=109
LP_ASUS
Community Legend I
If you view the photos on another device with Google Photos, do they also appear washed out?
I tested AccuBattery on my device as well, and it detected 5000mAh. See if updating the firmware to the latest version helps with either issue. https://www.asus.com/Phone/ZenFone-6-ZS630KL/HelpDesk_BIOS/
LP_ASUS
Community Legend I
After some more research, apparently the picture issue is related to a change in Google Photos. A future update to the app should resolve it.
coderedcomputin
Correct, viewing in any other device inside Google Photos the pictures are normal with no washing out/brightness increase.
Where can I confirm my current FW on the phone?  It did an OTA update when I got the phone on the 13th (USA).
