Bluetooth headphone problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-13-2020 03:54 AM
Then after phone call end the notification sound comes (information about last call charges) and then phone get restated it happens sometimes after update
I thinks this are all bugs please get in to note to slove the problem in next update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-13-2020 04:19 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-13-2020 05:09 AM
prashanthBut my problem is different, video and audio was playing but no sound in headset i have 2 blutooth headphones both are getting same problemhttps://zentalk.asus.com/en/discussion/16559/bluetooth-bug-in-121-update#latest
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-14-2020 02:24 AM
The other issue with no media audio is new.
Can you please make a screen recording where you show me your sound settings, watch a youtube video (where you don't hear any sound through your headset) and turn the volume all the way down and then up again. In the video, the sound should be there regardless of volume or you're having some other issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-14-2020 04:05 AM
Anders_ASUS1st issue was solved after low down the volume of bt headset while call it won't re-start now (but need to be fixed by asus team)ok, so you're having two issues. The restart issue is know and the temporary fix is to set your BT volume to 3 out of 7. Then it won't restart.
2nd issue while I'm screen recording the bt headset sound was coming but after recording done, the sound get cut off.
I send my screen recording video ( inbuilt asus 6z) and at the same time recoding done by my other phone via camera recorder, the sound was coming in my blutooth headphones while screen recording , and then i stopped my recoding the sound from my bt headset also get stopped (youtube video was playing at the time)i tried to low and high the volume but no use.
But not all the time media get no sound, if i switch off my phone( kept for a minute) and power it on, audio get worked on bt headset but after some times sound went off, after the new update only I'm noticing this issue for past 7days
And note it down this issue happens not only on blutooth it happens in 3.5mm jack too
You can clearly see my problem in my 2nd phone video recorded
