Model Name: Zenfone6
Firmware Version: QP1A.190711.005.WW_Phone-17.18.10.2007.165
Rooted or not: NOT
Frequency of Occurrence: All the time
APP Name & APP Version (If your issue relates to the app): whole system
This started to happen when my battery issues and charging issues started to show up i think. Whenever i try to turn on bluetooth it just switches off (on the slider or icon thing). I can tap many times but nothing helps. Bluetooth devices are impossible to pair, they are not visible etc.
In reality i think the phone does try to turn it on but it takes like 1-2hours to make this happen, and then the bluetooth is on but the icon is not showing up for another hour or ever (sometimes). So what it looks like:
i activate bluetooth
it deactivates
i try again it does it again
i wait 1-2 hours
the bt icon is not visible but i can find bluetooth devices and use them
sometimes after another hour BT icons shows in the bar, icon is on. SOMETIMES it doesn't show up even though bluetooth is operating and im using it.
sometimes restarting the phone does help speed up the activation
