07-07-2019
05:09 AM
- last edited on
01-16-2024
12:00 AM
by
ZenBot
07-11-2019 03:17 PM
07-12-2019 06:23 AM
Ofcourse, I did face the same problem, now it's just get hot when plugged in, but not stopped charging like earlier, I have faced a lot of issues with this smartphone, it's my first asus smartphone, very bad experience from ASUS product ????.mak.mahesh786 said:i recently manually updated my asus 6z, and now whenever i plug my charger, after sometimes it shows me that battery is overheating and the charging is stopped temporarily. is anyone facing same problem?
07-18-2019 04:10 AM
07-18-2019 04:38 AM
phone is idle, nothing going on, just charging with screen off.Anders_ASUS said:How hot is the room you charge the phone in and what are you doing with the phone while charging?
07-18-2019 06:21 AM
I am also facing the exact same issue. I just unboxed my new phone, there was a notification for an update so I did it. Now while charging it's constant beeping so when I checked it said charging stopped because battery is too hot. I wanted to know whether it's my device only or is it a software issue.mak.mahesh786 said:i recently manually updated my asus 6z, and now whenever i plug my charger, after sometimes it shows me that battery is overheating and the charging is stopped temporarily. is anyone facing same problem?
