Battery Drain
shreyashjoshi00
My battery is getting drained so fastly that It hardly crosses a day. Even if I'm just surfing around battery drops by 2-3%. Help me.
5 REPLIES 5
shreyashjoshi00
Plus my phone heats a alot even for normal use. Is it just me or anybody else is facing this problem?
Anders_ASUS
Hall of Fame III
You should be able to see in the battery settings "powermaster" what's draining your battery so fast. To get more details, you can install 3rd party battery monitoring apps. Any app with more than 4 stars and 1 million downloads should do the work.
Kamesh
Yes me too facing the same issue of overheating if any queries send me mail may be i will hlp u
kamesh.mahanandia@gmail.com
yogeio08
Heating issue will their always in this phone. Plus i was facing lot more issue like bootloop, white screen , green portrait shot, it restarts on its own. Finally returned to flipkart. Only used for 8 days. And had returned it yeaterday
