02-27-2020 01:15 PM
03-03-2020 02:34 AM
Kolorowezworkihttps://zentalk.asus.com/en/discussion/comment/46916#Comment_46916
You almost always recommend factory reset. Lagging after update? Factory reset or 3rd party app. Battery drain? Factory reset or 3rd party app etc. etc. Phone should work well after EVERY public update. If you have problems with deliver stable software, why not re-open beta testing? If you such love factory resets, please make it less harmful and give us a good backup method, but it shouldn't work that way. I haven't install any app for 4 months, and one update is better, one update is worse. I use my phone for calling, messaging and sometimes for taking pictures (since Android 10 quality is awful, but please don't recommend factory reset). I don't have root, I don't do any strange modifications of software, memory is used in 10 or 15% so don't try to tell me that problem with my phone is caused by something else than Asus development team. Device is amazing and we are understanding to you and your work, so don't treat us like dumbs and try to coop. We're playing in the same team.
bputra10bennyputraThere are probably a billion of different user scenarios that causes different behaviour on a phone. Most of those will never happen but let's say there are still a couple of thousands of more common user scenarios. That's still a lot and we can't foresee everyone. No one can.https://zentalk.asus.com/en/discussion/comment/46984#Comment_46984
thats right, im already keeping eye on this forum every single day in my office since im buying this phone, what makes me regret is i should have keeping eye on this forum BEFORE i buy the phone, not after.
i always read every single thread in this forum like everyday, and when i saw something that they can't fix, rather than working on with the updates, the moderators only said that we have try to reset it, and if it is not working, we have to go to the asus care center for replacement.
to be honest, im using iphone since like 7 or 8 years ago, trying to give this android a chance and decided to use this phone, but you know what , its pretty awful.
03-06-2020 07:58 AM
03-07-2020 02:19 AM
03-08-2020 06:16 PM
Kolorowezworkiso i think what he mean, you buy this phone, but do not use it as your main phone, because you never know when and why your phone need to factory reset. Can you imagine buying a phone but yet you are so afraid to do anything with it like installing apps or games or even put a lot of data in there, because you never know when your phone will encounter bugs with factory reset solution.https://zentalk.asus.com/en/discussion/comment/47499#Comment_47499
I don't say it won't work. Its just not acceptable solution. If factory reset works, then it's software issue, then could be repaired by proper update.
