02-27-2020 01:15 PM
03-01-2020 02:50 PM
gaurav.andLooks like it's stuck in wide angle view and this is why you see only 13MP as highest resolution. I don't have any explanation for the but my suggestion is that you should clear the storage of your camera app. If that doesn't help, then full factory reset. If that doesn't help, then please contact your local ASUS support for a repair.https://us.v-cdn.net/6031231/uploads/564/OSI6OBKBH016.mp4
After latest update, I am facing lots of trouble in camera . Lense is not working , wide angle option is not showing in photo mode,
Colour full dots is appearing in video, night mode & Time-Lapsed mode.
Portrait mode is not showing.
In setting , camera resolution menu showing only 13 MP, 10 MP & 8 MP .
Camera is unable to focus.
03-01-2020 05:04 PM
Anders_ASUSI aint paying my phone just to reset and factory reset my phone. This aint no cheap phone, yet the quality is like this, you better not selling this zf6 if the problem is unsolvable, i am not saying the phone must be perfect, but if any problem occur, factory reset is not the answer. Makes me regret changing my iphone 7 plus with this phone.https://zentalk.asus.com/en/discussion/comment/46707#Comment_46707
03-02-2020 01:10 AM
bputra10bennyputraThere's no need to worry. I can guarantee you that this won't happen to you. I always try not to suggest a factory reset if it can be avoided because I know how much work it is but in his case, where service is probably the only solution, factory reset is better if it shows that this is due to software and not hardware. But my bet is that this is a hardware issue that just happened to get triggered when the phone updatedLooking all of this problem making me scare to update my zf6. Plus the answer for all of this problem always like this
https://zentalk.asus.com/en/discussion/comment/46807#Comment_46807
03-02-2020 10:07 AM
Anders_ASUSYou almost always recommend factory reset. Lagging after update? Factory reset or 3rd party app. Battery drain? Factory reset or 3rd party app etc. etc. Phone should work well after EVERY public update. If you have problems with deliver stable software, why not re-open beta testing? If you such love factory resets, please make it less harmful and give us a good backup method, but it shouldn't work that way. I haven't install any app for 4 months, and one update is better, one update is worse. I use my phone for calling, messaging and sometimes for taking pictures (since Android 10 quality is awful, but please don't recommend factory reset). I don't have root, I don't do any strange modifications of software, memory is used in 10 or 15% so don't try to tell me that problem with my phone is caused by something else than Asus development team. Device is amazing and we are understanding to you and your work, so don't treat us like dumbs and try to coop. We're playing in the same team.https://zentalk.asus.com/en/discussion/comment/46812#Comment_46812
03-02-2020 05:11 PM
Kolorowezworkithats right, im already keeping eye on this forum every single day in my office since im buying this phone, what makes me regret is i should have keeping eye on this forum BEFORE i buy the phone, not after.https://zentalk.asus.com/en/discussion/comment/46916#Comment_46916
