Battery Charge slow 420 mA
Rodolfo
Good Morning. My phone has stopped charging fast sometimes charging for 8 hours has anyone had this problem? I did an ampere test and gave 420mA when charging I find very little. Before asking the smart charger is disabled.
ASUS Zenfone 6, 8gb ram, 256gb
6 REPLIES 6
GamerArc
Rising Star II
You should check with a different cable.. by constant bending and twisting the internal wires in the cable breaks and the speed slows.. so check in amps with other cable and then post back the results.
Rodolfo
the phone was a month old when it happened I was always very careful about the cable but I will try to test with another cable. thank you
GamerArc
Rising Star II
Most likely its a damaged cable. Check back and let us know.
Rodolfo
really was the damaged cable, i bought one from sbs type-c with the specifications: charging function, data transfer and sync enabled, connector 1: usb 2.0, connector 2: usb 3.0 type c is suitable for my zenfone 6 right? Thank you for your help
